Re: IH 674 Diesel - Air in system?
Posted by JimB2 on October 01, 2008 at 18:21:25 from (99.241.179.24):
In Reply to: IH 674 Diesel - Air in system? posted by Floridaboy on October 01, 2008 at 11:28:40:
Go to www.caseih.com then parts and D-239 search and it will show all the possible fuel filter types.
D-239 is the engine type and it was used in several different applications and early models had only tin canister fuel filter with a drain on it, later models had 2 fuel filters on right side of engine with small bowl on bottom. The bleed screw was usually a hex head screw with screw driver slot in head.
It still suspect you will find problem is in the outlet of fuel tank. My brother's 684 had the remains of a lady bug corps stuck in the outlet that would give the same symptons.
Lets us know the out come.
JimB
