Posted by charles todd on October 01, 2008 at 18:33:16 from (205.242.95.138):
I recieved my Farmall 504 as a hand-me-down from my father last year (2007). It was the smallest and oldest tractor on his cattle farm (150 acres). The poor tractor was the red-headed step-child of the fleet.
I had to take care of some leaks on the engine, axle housings, axle seals, pto seal, quadrant leak, ect. I gutted the OEM wiring harness and started over after a meltdown. Installed a Delco 1-wire and fixed all electrical problems. I also fixed replaced nucience items like the broken precleaner and rusted cap, blown out muffler, relocated the remotes, and repaired the worn steering linkage and tie rod ends. The biggest feat was installing a new Koyker 220 front end loader with 6' bucket (AWSOME).
The only thing left was the shift quality. At least 10-12 years ago we split the tractor and replaced the main clutch and TA clutch. The TA never worked to my knowledge up to this time. We assembled it all and the main clutch (button style) was badass! Positive and no slip. The TA was lacking, actually no change... We split it again and tore into the TA. We replaced the rollers (flat) and ramps (worn). We had a machine shop knurl something in the TA, maybe the outside of the inner sprag? Anyway we put it all back together and the TA worked! The only problem, it was too aggressive.
Years later I own it and finally I had enough. When in DD if you came to a complete stop the shift lever would be in a bind. You would have to pull the TA lever into TA to relieve pressure on the shift lever. I always assumed it was due to knurling worn parts and the TA was binding. I got out the I&T manual, Farmall Operators Manual, and the Blue Ribbon Manual and studied them. I used the method in the Farmall manual to adjust the TA and Main clutch linkages to spec.
I cranked it up and I'll be a monkey's uncle, it shifted like a new tractor (almost!). All these years and the hard shifting was just poor linkage adjustment. I tried all gears in DD and TA. I could not hold the tractor in TA 1, TA 2, TA 3, or TA 4 with the brakes (properly adjusted). In TA 5, I could stall the engine out with the brakes at 1/2 throttle.
In this novel I have written, the moral is if the TA is not acting correctly or the transmission is hard to shift, sit down and read the manuals. Most likely the linkages are out of adjustment or out of time with each other (lot going on down there).
Thanks to all the seasoned IH guy out there that have put up with my relentless question asking.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
