Ed1, I am not arguing with you on the 504's capabilities. Just sorting that out first. The 504 is a 3 PLOW tractor, fact. I have never ran a 5 speed gasoline 504, but I am more than confident a diesel TA 504 will pull 3-16's. I know for a fact a diesel 504 will pull a 10' disk all day with loaded tires. I know it can (with a struggle) pull a 4 yard Reynolds scraper in 1st gear (6ft+ cutting edge). The only thing I have seen drag the diesel 504 to its knees is a 5 shank chisel plow in Louisiana clay.
Bud in SC
1. The serial number puts it at 1962.
2. There is no I in the list I have, but a J for Rockford clutch.
3. W is for forward/reverse shuttle shift. I would buy a parts tractor just for this item to put on my 504. For using a loader it is invaluable. Buy it, if you find it too small I'll buy it from you later on (seriously).
4. Y is for 12 GPM hydraulic pump.
5. FF is for a 4.5 GPM 3-point/fast hitch pump.
4 and 5 are the most common pump options on a 504. Is this a wide front or tricycle? I would like a picture of the tractor if you end up buying it. Especially the fwd/rev unit. Finally, I'd give $3200 for it without thinking twice if it checks out mechanicaly sound with decent rubber on the rear.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
