Re: Do these tires make my tractor look fat?
Posted by Gene Bender on October 02, 2008 at 03:33:48 from (67.55.226.167):
In Reply to: Do these tires make my tractor look fat? posted by Harold Hubbard on October 01, 2008 at 19:30:12:
Why are you using front wheel weights if the frontwheels are causing too much wt problem. Those weigh 42lbs ea. If your front wheels are the adjustable rims you can space them wider an this will help. The Char-Lynn power steering unit would be easy to install. Just mount a power steering pump under the gen. Know of a couple done that way and they work well.
