Re: 113/123 Governor
Posted by Bob on October 02, 2008 at 07:29:16 from (69.178.228.68):
In Reply to: 113/123 Governor posted by jal-SD on October 02, 2008 at 07:13:56:
You have to remove the governor housing from the front of the engine to expose the governor/mag drive. Be SURE to find the timing marks BEFORE pulling the governor/mag drive out of "mesh" with the timing gear.
