Re: 42 H Cutoff rims
Posted by ctide on October 02, 2008 at 11:01:16 from (168.91.1.189):
In Reply to: Re: 42 H Cutoff rims posted by Steven f/AZ on October 01, 2008 at 12:50:52:
It is hard for me to tell. The stamped and bent piece plus the spokes look the same. You may have the hubs and bolts on the inside where I can't see them. I will look at mine from a different direction and see if I can match up. I am the second owner and was told it came on steel i.e these rims and then cutoff and converted. The fronts were just jeplaced with the newer wheel.
