Re: Farmall M Thermostat
Posted by Bob M on October 02, 2008 at 12:02:00 from (151.190.254.108):
In Reply to: Farmall M Thermostat posted by konstan on October 02, 2008 at 11:14:51:
The AZ #800-180 sounds right - though it's been a few years since last purchased one. Seems to me also it fit some 70's era big block Olds/Pontiac engines. But it's been a while...
Anyway suggest you pull the old t'stat and bring it to a parts store. Or if the t'stat breaks apart when you remove it or it is MIA, bring in the t'stat housing. Then find a t'stat with the correct outside diameter flange to match the old t'stat or housing.
Keep in mind the new t'stat will be much shorter than the OEM. However it will fit and work fine (FWIW I now have several H's and M's all with 180 deg car thermostats in 'em now.)
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
