Re: fixing leaks
Posted by jakinator on October 02, 2008 at 12:18:17 from (63.254.149.125):
In Reply to: Re: fixing leaks posted by Janicholson on September 28, 2008 at 15:20:31:
jim, I have belly mower brackets attached to 2 bolt holes at the bottom,inside end of rear axel housing. it looks like fluid leak is coming from where the brackets are attached...the seals where the axels bolt to rear end do not appear to be wet to the extent of the amount of fluid leaking out. thanks for taking time to help
don
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
