Re: sickle bar for a B
Posted by Steven f/AZ on October 02, 2008 at 12:52:18 from (216.67.213.217):
In Reply to: sickle bar for a B posted by jakinator on October 02, 2008 at 12:37:08:
There are several that would work...
Easiest would be a pull type, the balanced head drive (pitmanless) would be a model 100 or 1100.
You could also have a semi-mount 120 that would work on a B.
There would also be some fully-mounted IH mowers that will work, such as a 110, 1110, etc.
Pics here: http://ytforums.ytmag.com/viewtopic.php?t=376107
