Posted by RN on October 02, 2008 at 12:56:14 from (96.60.81.245):
In Reply to: m pto speed posted by ckfarmall on October 01, 2008 at 20:42:04:
Trying to remeber old M speed- governor was 1600/1650 full trottle and PTO would do the 525/560 range for nominal 540. Variations exist- 1450 governor setting on earliest, Super M with 1750/1800 governor had matching PTO gears- if your M was every rebuilt the later governor weights and springs may have been installed. Industrial 2000 rpm governor parts also exist and are sometimes installed- Don't think they had PTO gear ratio the same as standard but many Industrials didn't have PTO- had extra hydraulic pump instead. If you have a tach on M, check the 1450 setting first under light load, otherwise get set throttle 2 notches back from full and see how it works. RN
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
[More Ads]
