You are correct. I haven't seen that setup before. We had a 674 for about three months and traded for 684 with T/A so never changed fuel filters on it.
Here is my suggestion for primary fuel filter bleeding, with your hand on the bottom of primary fuel filter holding filter assembly in place loosen nut # 11 a few turns and let fuel escape until air bubbles stop then tighten nut. Primary filter should be full without air, next bleed secondary via screw #13.
Some positive air pressure in fuel tank will assist in bleeding and priming the Bosch injection pump.
So on that model does the fuel line from the tank come in one of the inlets just above the #8? The 684 has 2 bleed screws and the tank inlet comes in from the top of primary filter.
Another quick check is the STOP/START/RUN control cable on the side of the Bosch injection pump. In STOP position lever on the side is all the way back against the adj. screw. In START position the lever is about 1/3 the way to front limit adj. screw and the plunger is exposed from barrel of the excess fuel plunger. In RUN position the lever is all the way forward limiting on the front adj. screw.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
