Re: water in oil pan
Posted by ScottyHOMEy on October 02, 2008 at 19:49:55 from (71.241.211.254):
In Reply to: water in oil pan posted by 7lazy77 on October 02, 2008 at 19:31:44:
If there's antifreeze in the cooling system and no indication of it in the crankcase, I'd trust my eyes and nose and for the moment assume that it's condensation or rainwater down the spout.
The best check you can do at this point is to change the oil out again (let it settle for a couple days before changing) at ten hours or one month. I've got an idea you won't detect anywater at the second change. If you should, and it still doesn't contain any antifreeze, there really isn't much to explain it except condensation, as long as it's been undercover or at the least had a can over the exhaust.
I suspect you're just fine.
