I suggest that you have an auxiliary reservoir somewhere.
There is nothing wrong with your system. 6 quarts of oil is only enough to lift the loader 6 feet before it runs dry. Keep trying to lift the loader beyond 6 feet without filling your auxiliary reservoir, and you WILL damage the pump.
Is there a hose running into the fill pipe on your belly pump? Follow that hose. It will lead you to an auxiliary reservoir. On older loaders, the tops of the lift cylinders were often used as auxiliary reservoirs. Sometimes there's an external tank. Sometimes the frame of the loader itself is the reservoir.
To fill the auxiliary reservoir, lift the loader about 5 feet. Refill the belly pump. Lower the loader to push the fluid into the auxiliary reservoir. You may need to crack the reservoir hose at a connection to bleed the air out.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
