Re: International Super A foot throttle
Posted by RedJohn-2 on October 03, 2008 at 12:46:58 from (70.119.35.69):
In Reply to: International Super A foot throttle posted by jwilbur on October 02, 2008 at 18:36:20:
Joe, I forgot to add: You can interchange the axle, but you have to use the steering gear housing base that is used on the round axle. This base utilizes the small pivot shaft. The heavy duty axle (diamond shape) utilizes the heavy duty base which accomodates the large pivot shaft. The steering gear arm is bent a little different too, but it really won't matter. The foot throttle can be installed on either A,AV,AI,SA,SAV,SAI. If you don't want it, several people will. John
