Re: Farmall H, what jobs did they do on the farm?
Posted by mkirsch on October 03, 2008 at 13:13:40 from (64.80.108.53):
In Reply to: Farmall H, what jobs did they do on the farm? posted by I need a handle on September 23, 2008 at 07:24:38:
I need a handle said: (quoted from post at 07:24:38 09/23/08) The M has got to have a thicker hub. I know the M has got bigger axles so it couldn't be the exact same hub.
It's also got more horsepower and more traction.
Everything is in proportion. More power needs bigger axle and thicker hub.
I suppose if you put an H engine in an M, or got an M with a weak engine, you'd be on track here.
Disappointed? This is a 60-year-old tractor we're talking about here, not a new John Deere. God only knows what kind of abuse that tractor has seen in those years, what kind of neglect. You may be doing everything right, but if someone let the hub run loose 20 years ago, the damage was already done. The first heavy load, and POP, there she goes.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
