Re: H Just Stopped Charging...
Posted by leroy in ne on October 03, 2008 at 18:31:59 from (67.63.106.62):
In Reply to: H Just Stopped Charging... posted by Crazy Red Power in SE-WI on October 03, 2008 at 18:12:34:
generator regulator set up with low high positions on light switch? if so simple test of generator, ground field lead (small wire) at generator should show full charge, 10 or 15 amps, if not take to generator rebuild shop after checking all conections. also possible bad amp meter, test for voltage output with meter, my memory is not what it was but i beleive 6.8 to 7.2 volts is correct. hard for me to describe what i would check as i just start eliminating possibility's by various methods with what i have available when problems occur
