Re: Farmall H grinds in all gears except 5th
Posted by Brownie 450 on October 04, 2008 at 04:58:22 from (216.51.158.151):
In Reply to: Farmall H grinds in all gears except 5th posted by Thomas Keiber on October 03, 2008 at 21:50:08:
You can check for bad rear axle bearings by jacking up each side individually & taking note how much the axle/ wheel moves as the wheel leaves the ground [vertical play].
While you have it on the jack, roll that wheel & listen for noise in the differential.
