It probably has countershaft bearings, and or constant mesh gears that are either worn, or damaged from rust. Many transmissions get water in the case then sit and rust, quite often unevenly. Roller and ball bearings are particularly subject to this damage. Another issue is the metal fragments from decomposing bearings and gears contributing to added wear (becomming in effect an abrasive slurry. The top is heavy enough to require three or four people, or a suitable lifting device. The trans and differential can be stripped to the walls with the tractor intact. The liftall needs to be removed to allow the clutch shaft to be removed. Get a good blue ribbon manual, and an IT manual to be confident. JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
