Re: IH 4 cyl Gas engine UC135B Timing
Posted by Janicholson on October 04, 2008 at 06:48:06 from (66.188.163.79):
In Reply to: Re: IH 4 cyl Gas engine UC135B Timing posted by Bob Chadwick on October 03, 2008 at 19:37:58:
The first timing mark to come to the pointer is TDC. The static timing is set there. Advance timing is to the second mark. (assumes it is like the C-135 in a tractor, and probably is)
