Gear oil
Posted by rustin on October 04, 2008 at 08:28:32 from (72.36.61.204):
I don't have an IH dealer that is reasonably close. I did find some straight 90 weight at the local farm & ranch store. It is made by Harvest King & says GL-4 SAE 90 on the bottle. Just was wondering if this would work on the Farmall/IH?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
