Re: Farmall A and Super A Front Rims
Posted by Hugh MacKay on October 04, 2008 at 13:53:26 from (209.226.247.151):
In Reply to: Re: Farmall A and Super A Front Rims posted by Brian2 on October 04, 2008 at 13:31:32:
Brian: Adjustable rims can be installed inside or outside the hub with lugs turned in or out. Gives 4 settings on each wheel. All adjustable wheels have lugs welded or rivited to the rim. Non adjustable don't have the lugs welded or rivited to the rim.
You look at your A and SA hubs, I'm betting they are different. You can't put a non adjustable rim on a hub designed for adjustable rims, or vice versa.
