Narrowing up B.N. to A Width. Post # 2
Posted by 1 morgan on October 04, 2008 at 14:03:02 from (4.156.246.179):
Hey guys: There are two parts to this ? Does anyone know if the A will pull better for tractor pulling than the B. N. because it is narrower. In the 2500 lbs. class if I had the narrow axle, it would weigth maybe 50 ibs. less, so I could put a little more weigth on frt. # 2 I would like run 13.6x24 tires that also weight a little more. Also does an A also use the cast weight on one side? That should be on the right.side as you sit on the tractor I guess. Any help would be great Thanks............
