Re: Farmall H grinds in all gears except 5th
Posted by MN Rick on October 04, 2008 at 14:23:24 from (71.210.131.199):
In Reply to: Farmall H grinds in all gears except 5th posted by Thomas Keiber on October 03, 2008 at 21:50:08:
A little grinding is somewhat normal if you dont wait a second or so after depressing the clutch. One other possibility that hasnt been mentioned. Occasionally you will get a buildup of clutch material, rust, dirt, grease ect on the flywheel around the outside of the clutch plate causing just enough drag on the plate to keep it from stopping. Over the years, I've split a number of them only to find good clutch parts.
