The only part that is now longer turning when in 5th as compared to the other gears is the front mainshaft bearing. There is also no load on the countershaft in 5th as there is when in the other gears. Do you hear the noise when idling in neutral with the clutch out?
The front mainshaft bearing can be replaced after removing the Lift-All pump, driveshaft coupler, front input shaft yoke, and the input shaft assembly.
The front mainshaft bearing is often referred to as the transmission pilot bearing. Look back through some of the older threads and you will see a lot of discussion about it.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
