Re: H and M flat belt pulley question
Posted by Haas on October 04, 2008 at 17:16:52 from (12.65.24.50):
In Reply to: H and M flat belt pulley question posted by Steve Atkns on October 04, 2008 at 09:00:21:
As Randy said, bolt patterns are the same and H and M pulleys are interchangeable. There are many different sizes of pulleys, depending on how fast you want the belt to run. The larger the pulley, the faster the belt speed. Also, I believe the H belt pulley turns faster than the M and therefore the H came with a smaller standard belt pulley than the M. So if you are going to run something with the belt, then you need to size the tractor pulley according to required RPM of the implement and the implement belt pulley size. If you are not going to use the pulley, then just put on the size that you think looks best.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
