Re: H and M flat belt pulley question
Posted by Gene Bender on October 04, 2008 at 17:18:02 from (67.55.226.167):
In Reply to: H and M flat belt pulley question posted by Steve Atkns on October 04, 2008 at 09:00:21:
Both tractors had different sizes avail to run different machiones all depending on if you ran a threshing machine with a pulley that would match the tractor. A F-20 would run a threshing machine better than the H or M unless you matched pulleys to get cycl speed. Seen that happen
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
