Re: cub wiring diagram
Posted by Janicholson on October 04, 2008 at 20:17:48 from (66.173.50.157):
In Reply to: cub wiring diagram posted by L. McIlravy on October 04, 2008 at 19:30:55:
This should do for wiring.
If it has a mag it is a kill switch that grounds the mag. If it has a generator and regulator, the three position is correct. If it has a cutout relay and no regulator it needs a four position switch.
The Ignition switch with a distributor ignition would usually fail to no start from no spark, not no battery power to starter. It could be not charging the battery. Which way does theAmp meter move when running? JimN
