Re: 404/460 Ute Questions
Posted by J.J. from Afton on October 04, 2008 at 22:11:59 from (139.225.250.243):
In Reply to: 404/460 Ute Questions posted by Ksfarmmer on October 03, 2008 at 19:36:40:
Well the big thing to pay attention to on the 460s is the steering. They are well known for excessive wear in the steering box, especially if theve had a loader for a long time. However they also have an advantage over the 404 in that they have frame rails along the einge, where as with the 404 the block is "the frame" between the bellhousing and the front end. As far as loaders I have seen several of each model with loaders on em.
Personally Id say go with the 404 cause they are a little more compact as far as length. Also they are newer than the 460. But from what Ive heard they are bit more challenging for finding parts since they are not as common.
But if and when you get a loader for it be sure its one that mounts to the rear axle in addition to the bolster and torque tube so that all the strain is not just on the bolster and torque tube. Otherwise you are more likely to have the tractor in two pieces if someone ever tries to lift something they shouldnt.
Hope this helps you.
