Re: McCormick-Deering bad motor - which rebuilt kit??????
Posted by moseed on October 05, 2008 at 07:48:36 from (207.177.239.36):
In Reply to: McCormick-Deering bad motor - which rebuilt kit?????? posted by Dave Koenigsfeld on October 01, 2008 at 19:37:55:
Dave Koenigsfeld said: (quoted from post at 19:37:55 10/01/08) All great comments! It is good to know that the w30 is a good donor. what about a 15-30?
James - dumb question...can you bend the crank by pounding on the pistons or do you take the lower cap off first?? I may start pounding on the other motor to get started.
El - we are looking at a guy in OK.
Jon - thanks for the link, I"m already looking at some tractors on his site 10-20!!!
thanks again, I really appreciate it.
Dave,
Disconnect the rod/s from the crank if you are going to beat on it. If your going to leave the crank in make sure the rods are away from the crank (after taking bearing cap off) so you minimize the potential of scracthing the journals should it give way and move significantly.
Big project and all the luck and money in the world!
Good luck.
Dave
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
