Re: HELP SMD KNOCK
Posted by Janicholson on October 05, 2008 at 11:19:27 from (66.173.50.65):
In Reply to: HELP SMD KNOCK posted by DGK on October 05, 2008 at 05:06:52:
It could be a plugged up carbon deposited spark chamber causing preignition knock on one cylinder.
Pull the plugs and look(as much as possible) inside the hole. another issue might be a stuck or broken third valve system leaving one cylinder With no compression relief. It will knock if that is the case!!! JimN
