Posted by ScottyHOMEy on October 05, 2008 at 14:22:51 from (70.105.228.59):
In Reply to: C clutch posted by hicksdale on October 05, 2008 at 13:39:11:
Jeeze I wish ya hadn't done that. ;8^) Good part is that WD40 is more of a solvent than a lubricant. It penetrates pretty good, but I don't expect much of it got to the frictions surfaces of your clutch disc.
For a tractor that's been sittin' it's far more common for the faces of the clutch disc to stick to the face of the flywheel or the clutch cover rather than the shaft. To get that loose . . .
Try pulling something with your tractor. The tractor should be in gear and the clutch pedal should be depressed. The idea is that you want the whole mechanism to be in the "clutch released) position while you put enough load on it to break loose the bond holding the face of the disc.
The object you pull should not be a fixed object like a tree. You could break something trying that.
If you have something like a 3-point counterweight for a front bucket that can be dragged that can work. Another is to pull a regular road vehicle. As you pull with your clutch depressed, have a driver in the vehicle you're pulling apply their brakes to put a strain on, lock it up and drag them if that's what it takes.
Depending on what shape it was in the last time it worked properly, six months isn't all that long a time for it to have been setting. I have an idea it might break loose fairly easily.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
