Re: C clutch
Posted by old on October 05, 2008 at 14:44:53 from (4.244.186.5):
In Reply to: C clutch posted by hicksdale on October 05, 2008 at 13:39:11:
WD-40 bad, brake cleaner good. Tie or block the clutch down and spray the clutch disk with brake cleaner. The take it out in an big open place and start it in gear and drive it around holding the pedel down. Very common problem on those old tractors and what happens is the clutch disk rusts to the flywheel and because of that they then stick and need to be run to pop loose or taken apart and the clutch serviced. BTDT many times
