If you take the advance cap off ( the one that the rod attaches to to advance or retard the spark), you will notice a small piece of metal at about 4:00 on the housing that turns. That is the ground point. if it is not bent the corect distance from the mag housing, it will not contact the points connector to ground it out.
Take your cap off and rotate the advance, you will see the piece of metal that I am talking about. When fully retarded, it should contact the points connection, and ground it out. If it does not make contact with the points, carefully bend it enough to make contact.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
