Assuming your polarities are correct (I believe they are) the only possible answer is that the generator is shorting to ground internally. It could be many things, but there is no way it should make warm wires doing the test. Disconnect the gen from all wires. If you can get through the endframe, to the brushes, use a pic or pointed wire to lift them off of the armature. Put a piece of card stock under them to insulate them from the commutator bars. Then test the resistance of the Arm terminal to ground. If it shows ground, it has a short. If not, it will require disassembly of the gen to test the armature for shorts. Google Delco Remy A type generator images/And info. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
