Re: hydraulics on an 856 international
Posted by the tractor vet on October 05, 2008 at 18:23:02 from (99.167.208.219):
In Reply to: hydraulics on an 856 international posted by howard mills on October 05, 2008 at 18:01:09:
the main hitch pump is located in the lower left of the rearend just ahead of the left rear axle . My be something as simple as a sheared key on the pump drive gear .A new key a new lock nut one gskt . and a O/RING will fix that. You must drain the hyd, oil and to do this you will need the bottom third of a 55 gallon drum and it will darn near fill it . Now if this is not the problem you did not say if you have steering and breaks and if the tracor will or will not move if it has a T/A . Now if this is the case then the repair gets a little more involved as the tractor will have to be split at the bellhouseing and you will need a new pressure plate a PTO input shaft bearing seals and gskt and since you are replacing the pressure plate ya might as well reface the flywheel and put in a new clutch disc.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
