Re: hydraulics on an 856 international
Posted by charles todd on October 05, 2008 at 18:25:52 from (205.242.95.134):
In Reply to: hydraulics on an 856 international posted by howard mills on October 05, 2008 at 18:01:09:
I do not know how the 856 is set up, but most IH's are similar. My 504 lost all remote hydraulics, but had steering, same pump. I found either a check valve had trash in it or the relief had trash in it. I say either because after cleaning them, it worked.
Your problem sounds like the entire hydraulics have failed. The pump(s) have a drive gear that is keyed to the pump input shaft. When I changed my pump, the key and keyway was VERY worn. I was about to shear the key, good thing I was changing pumps.
If you have a manual or know where the pump is, I'd pull the pump and check the key. If that checks out good, look for a stuck relief or check valve.
Charles
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
