Posted by charles todd on October 05, 2008 at 20:09:22 from (205.242.95.134):
In Reply to: cub wiring posted by L. McIlravy on October 05, 2008 at 19:30:03:
This is what I use, regardless of what type of tractor. Use 10ga on charging circuit from alt/gen to battery, use 12-14ga on lights, use 14ga on any other circuits to 15 amps. 16ga is good to 10 amps, but a little corrosion on a terminal lowers that value.
As for connections, I have two methods. Soldering is best, no substitue for quality soldering job. This is time consuming to solder each part. When I solder, I crimp first then solder the sta-kon terminals. The second method is to get some dielectric silicone grease and squirt some in EVERY fitting before you insert the wire and crimp. This helps drive away moisture and corrosion.
Anything less and you WILL revisit the wiring again, its just when. Personally I solder everything I can, use silicone grease and crimp the rest.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
