Re: 674 After Hydraulic filter change, no pressure
Posted by shadetree mechanic on October 06, 2008 at 08:21:37 from (162.27.9.20):
In Reply to: 674 After Hydraulic filter change, no pressure posted by hrhoward on October 05, 2008 at 16:19:01:
I haven't done this in awhile, so I'm trying to remember the specifics. You'll have to remove the plug under the filter on the bottom of the MCV body. I think it takes a 1 1/4" wrench. Remove the plug, then let the spring fall out. There may even be a valve along with the spring. Put the bucket under the hole and start the tractor. After a few seconds, oil will come flowing out. Shut off the engine and put the parts back in the MCV body. When you start the tractor the next time, you should have hyd. pressure. I have to do this every time I change the filter. They say its because the pump is worn and can't prime itself. Hope this helps!
