Re: 1066 PTO noise
Posted by mjs on October 06, 2008 at 09:20:38 from (199.153.192.254):
In Reply to: Re: 1066 PTO noise posted by Cor Braakman on October 06, 2008 at 08:51:47:
I am going to recheck this tonight. The owner's manual says from end of pto shaft to C/L of hitch pin should be 16". Only question here is that on a JD tractor that I assume they are referring to in the manual which is interchangable in the same hole as the 540 shaft vs. that 540 and 1000 shafts on my 1066 being in different locations. One would have thought that if this was an issue it would have made noise on both the right and left turns though!
