Re: DT466 Engine Problems
Posted by El Toro on October 06, 2008 at 09:48:23 from (205.188.116.73):
In Reply to: DT466 Engine Problems posted by ihdoug on October 05, 2008 at 22:47:45:
Are you sure its getting fuel? Could be dirty fuel filters, blockage in the fuel tank. You didn't mentioned that it was knocking. Drain some of the oil from the pan and look for metal particles. Bearings may be ok if oil looks ok.
Hal
