Re: M Hydraulics
Posted by Janicholson on October 06, 2008 at 10:17:01 from (199.17.6.128):
In Reply to: Re: M Hydraulics posted by b OLSON on October 06, 2008 at 01:18:09:
Then I would block up the loader so that all weight is on the bucket (On a plank or 4X4 or two), and the bucket cylinder is also not under load. I would remove one of the lift cylinders, and lay it so the hose connection is highest, and the cylinder is lower to the other end. Then I woule operate the lift lever to extend that cylinder. Then I would put it in the Lower position with the engine off, and manually push the cylinder in to its shortest length while keeping it low on the ram end (not past the shiny part of the ram, just to where it normally goes. I would do this several times, then check and refill the resivoir. Then I would reattach the first, and do it to the other side the same way. Again check the fluid level.
Re-attach and try it. I would also check the tilt cylinder for air in a similar manor, Both ends if needed. This is an open center system, and (I assume you wire back the main lift rod to use different spool valves) if you attach a third valve to the return hose going to the reservoir that must also be a open center valve with its return line attached to the reservoir. Good luck, air can be troublesome to remove. JimN
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
