Re: farmall a charging system
Posted by Janicholson on October 06, 2008 at 10:25:55 from (199.17.6.128):
In Reply to: farmall a charging system posted by dbanjo0335 on October 06, 2008 at 07:04:54:
The most common error is to install the battery backwards. All (with no important exceptions)are negative ground. If it is installed incorrectly it will smoke the alternator and wires. (the diodes in the alternator will condict full battery amps (hundreds) into an aparent short circuit. Not good. The attached diagrams will make sense and detail the components. Thank Bob, they are very fine work. JimN
