Re: 340 U Hydraulic Fitting size and type?
Posted by BMD on October 06, 2008 at 16:30:27 from (65.254.172.6):
In Reply to: Re: 340 U Hydraulic Fitting size and type? posted by PaulW_NJ on October 06, 2008 at 16:20:35:
Thank you sir!. Now that I know the type(ORB) and using the chart for the thread size 1-3/16 I have a 7/8 which is a size 14.
Now I can order fittings and get the right ones first time out. Buying hydraulic gear and fitting that are incorrect is a expensive waste.
The bookmark is excellent reference.
thank you......
