Re: 1066 PTO noise
Posted by leroy in ne on October 06, 2008 at 16:34:58 from (67.63.106.62):
In Reply to: 1066 PTO noise posted by mjs on October 05, 2008 at 19:41:05:
need help explaining what i remember. something about timing u-joints and acceleration/deceleration of joint as it flexes will cancel each other as long as angle of both joints is the same. however with a trailed unit like a baler or combine the wheels of unit are not equally spaced from center line of tractor resluting in change of angle when turning toward offset side creating sharper angle of drive shaft resulting in u-joint hammer. maybe i'm all wet and need smartening up if so help will be appreciated leroy
