Re: M bolster question
Posted by Bob M on October 06, 2008 at 17:30:43 from (74.74.140.194):
In Reply to: M bolster question posted by Etnfarmboy on October 06, 2008 at 17:20:15:
There is a tapered spline connection between the gear and the top of the pivot shaft. Once the spline lets go the pivot shaft will drop freely out of the bolster.
Presuming you've removed the lower bolster/front wheel assembly, put a jack, some piled up wood blocks or similar under the pivot shaft flange so the shaft does not fall out when the spline lets go.
Note! It'll probably require suitable puller - or a few good hammer licks - to break the gear free on the spline.
Good luck!
