Re: M bolster question
Posted by glennster on October 06, 2008 at 18:33:30 from (68.60.242.156):
In Reply to: Re: M bolster question posted by Etnfarmboy on October 06, 2008 at 17:35:35:
bob m has it. be careful, that shaft is heavy!!!. what i do is back the retaining nut off the upper gear, but be sure it still has full threads on the shaft. if you have a good size 2 or 3 jaw puller, you can get it on the outside of the bolster housing, real hard to find a puller that will grab the gear. snug the gear puller up, then give the center bolt on the puller a smart whack with a hammer. it should pop the gear off, and the nut will hold the shaft from falling out.
