Re: what's in the bottom of the oil pan?
Posted by Tom Windsor on October 06, 2008 at 18:58:43 from (71.28.88.201):
In Reply to: Re: what's in the bottom of the oil pan? posted by Janicholson on October 06, 2008 at 16:28:35:
YOu should be feeling the screen on the oil pickup. The oil pickup is attached to the oil pump in such a manner as it will rotate up and down but not sidewise.
