Valve Kits for W4
Posted by Ron Haling on October 07, 2008 at 03:14:21 from (124.187.118.177):
I am restoring a 1945 W4 Serial No 13394 in Australia which is a Petrol/Kerosene engine.I need to replace the Inlet and Exhaust valves but am confused that there are 3 different sets:
Gas (which I presume is Gasoline)
Kerosene
Gas/Distillate
The valves differ in length for these 3 listings.The valves in my tractor relate closest to the Petrol/Distillate listing
All W4 tractors that came to Australia were of the Petrol/Kerosene type
Can anyone help me with this problemin which valve set to get.
Also I wanted to out dome top pistons in this tractor.Original pistons are flat top.Can I put these dome tops in this motor
Many Thanks
