Re: Using Hydraulic Lifts with a Famall H
Posted by GeneMO on October 07, 2008 at 06:27:56 from (216.74.198.226):
In Reply to: Using Hydraulic Lifts with a Famall H posted by Shawn O on October 07, 2008 at 06:00:47:
The H "lift all" will do just that, lift. It will not supply downpressure. If you have a cylinder with two ports you can put a breather in the downpressure side. You will just have to experiment to figure out which is which as I can't tell you. The lift all will lift the implement or whatever, then gravity will have to do the rest.
Gene
