You Will remove the cap screws on the unit to get the seal out and then you pull the unit apart try to turn it over first B4 u separate it and you'll see several tiny ball bearings(18 I think) will jump out and try to run away!!!When Separated, you will be able to easily punch out the bearing and take it to Napa.Also...Inspect the shaft the steering attaches to for pitting or grooves.In my experience thats where the leak is..You can get a speedi-sleeve to fix the damage.Take the shaft with you. Napa has them to.....when you go to put it back together,slap some grease on the ball bearings to hold them in the cup they belong in and reassemble....there u are!
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo
... [Read Article]
Latest Ad:
[More Ads]
